rvibodataprovider TRVReportIBODataProvider [VCL; LCL; FMX]
Events
Events
A data provider receiving data from InterBase and Firebird databases via IB Objects components.
Unit RVReportIBODataProvider;
Syntax
TRVReportIBODataProvider = class (TRVReportCustomDBDataProvider)
hmtoggle_arrow1Hierarchy
Description
This component provides data for a report generator component from InterBase and Firebird databases via IB Objects components by Jason Wharton.
SQL select statement
table name
To use this component, assign it to DataProvider property of TRVReportGenerator.
TRVReportIBODataProvider introduces properties:
property IB_Connection: TIB_Connection;
property DatabaseName: String;
property SessionName: String;
Also: MaxRows, AutoFetchAll, FetchWholeRows, ColumnAttributes, FieldOptions properties.
Internally, the component uses temporal TIBOQuery and TIBOTable components to handle data queries. The data provider properties and events are assigned to these components. If you want to assign additional properties to them, use OnDataSetCreated event.
In addition to the default query processing, you can provide another DataSet component in OnCreateDataSet event. This DataSet is not necessary needed to be TIBOQuery or TIBOTable.
See also
Data queries
