TRVReportGaugeVisualizer.MaxSize
Maximal diameter of gauge circles.
property MaxSize: TRVStyleLength;
All gauges displayed by the visualizer have the same diameter. It is calculated to fit the smallest cell.
If MaxSize > 0, it specifies the maximal possible diameter.
This value is measured in screen pixels or in twips (1/20 of point) or in EMU, depending on Units property of TRVStyle component.
Default value
0
