rvdxmemdataprovider TRVReportDxMemDataProvider [VCL]
Properties   Events
Properties   Events
An universal database-related data provider for report generators, that includes a special support for TdxMemData datasets.
Unit RVReportDXDataProvider;
Syntax
TRVReportDBMemDataProvider = class (TRVReportDBMemDataProvider)
hmtoggle_arrow1Hierarchy
Description
This component provides data for reports from datasets listed in the DataSets property.
dataset name (must be equal to one of DataSets[].Name)
queries of the following syntax:
DataSetName, Field1 = Value1, Field2 = Value2, ...
This syntax is explained in the topic about TRVReportDBMemDataProvider. It allows implementing master/detail reports.
See also
Data queries
