TRVReportColoredShapeVisualizer
Properties
Properties
TRVReportColoredShapeVisualizer visualizes numeric values by applying color and rotation to a shape.
Unit RVReportValueVisualizer;
Syntax
TRVReportColoredShapeVisualizer = class (TRVReportCustomShapeVisualizer)
hmtoggle_arrow1Hierarchy
Description
The shape is defined in ShapeProperties.
A color and a rotation angle of this shape depend on the visualized value. The visualizer searches in ConditionalShapeProperties for the item corresponding to the visualized value. If none of the items corresponds to the visualized value (it may happen for low values), the default color and rotation angle is used.
Shape size may be limited by MaxSize.
By default, the shape is inscribed in a square. You can stretch it by changing ShapeScaleX.
Examples
Example 1: ShapeProperties.Shape = rvrshArrow1, ShapeProperties.StartAngle = 180, angles in ConditionalShapeProperties are from -60 to -180 (so arrows are rotated by 180°, 120°, 60°, 0°), Gradient = False
SCVis_Arrows
Example 2: The same settings, Gradient = True
SCVis_GradientArrows
Example 3: ShapeProperties.Shape = rvrshCircle, LineUsesFillColor = False, LineColor = clSilver
SCVis_TrafficLight
Example 4: ShapeProperties.Shape = rvrshBluntPointStar, ShapeProperties.PointCount = 8, Gradient = False
SCVis_BPStar
Note: in all these examples, a visualized value is increased from left to right. The leftmost shape is drawn using Color and ShapeProperties.StartAngle. Colors and rotations of other shapes are defined in ConditionalShapeProperties
See also
TRVReportTableItemInfo.BackgroundVisualizers
