TRVReportAreaSizeVisualizer.MinSize, MaxSize
These properties define the minimal and maximal sizes for displayed shapes.
property MinSize: TRVStyleLength;
property MaxSize: TRVStyleLength;
These values are measured in screen pixels or in twips (1/20 of point) or in EMU, depending on Units property of TRVStyle component.
MinSize specifies the size of a shape corresponding to MinValue (or to 0, if MinValue is negative).
The maximal shape size (corresponding to MaxValue) is calculated from cell sizes, but it cannot be greater than MaxSize (if MaxSize is positive).
MaxValue cannot be less than MinValue (otherwise, it is ignored).
Shape
The size defines
rvrsshCircle
diameter
rvrsshSquare
side length
Default values
0 (meaning no shape for MinValue, and maximal possible shape size for MaxValue)
