TrvrActionReportWizard.UseCurrentStyleTemplates
Specify whether the target editor's StyleTemplates must be reset before the report template generation.
property UseCurrentStyleTemplates: Boolean;
This property is used only if the target editor's UseStyleTemplates property = True.
If UseCurrentStyleTemplates = True: the report is generated using the current values of StyleTemplates collection of the target editor.
If UseCurrentStyleTemplates = False: StyleTemplates of the target editor are replaced with ActionNew.StyleTemplates (if ActionNew.ApplyStyleTemplates = True).
Default value:
False
See also:
AccentedTextStyleTemplateName, ReportFooterStyleTemplateName
