TrvrActionInsertTable.OnIsIDFieldName
The event where the user can identify "id" fields.
type
  TRVIsIDFieldNameEvent = procedure (Sender: TObject;
    const FieldName: TRVUnicodeString;
    var IsID: Boolean) of object;
property OnIsIDFieldName: TRVIsIDFieldNameEvent;
When a list of fields is displayed for inclusion in a report table, all fields are selected by default, except for "id" fields (because normally they should not be shown to end-users).
By default, the action treats as "id" fields all fields with names that end with 'id' or 'code' (case insensitive). You can modify this behavior in this event.
Input parameters:
FieldName – field name.
Output parameters:
IsID – "is this an id-field?"
