TRVCrossTabLevel.ClearEmptySummaryCols
Allows or disallows clearing summary columns containing no values.
property ClearEmptySummaryCols: Boolean;
This value affects summary columns started on the next cross-tab level.
For example, in this template (the colored cells belong to the cross-tab header, the light blue color denotes the header for summary columns), the summary column is affected by TRVReportTableItemInfo.CrossTabulation.Levels[0].ClearEmptySummaryCols.
{#Category}
{#Product}
Total for {#Category}
{Year}
{Sales}
{sum(Sales)}
If the whole group of columns to the left of the summary column(s) contain no values, they are cleared and replaced to Table.CrossTabulation.TextForEmptyCells.
Note: as you can see, this property affects only summary columns inside the cross-tab columns. It does not affect to summary columns for the whole rows, and to summary rows, they cannot be cleared.
Default value
False
