<< Click to display table of contents >> TRVCamMultiView.OnSelectViewer |
Occurs when one of viewer windows becomes selected (focused).
type
TRVSelectCamViewEvent = procedure(Sender: TObject;
Viewer: TRVCamView; ViewerIndex: Integer) of object;
property OnSelectViewer: TRVSelectCamViewEvent;
A viewer window may become selected when the user clicked it with the mouse, or moved to it using Tab or Shift+Tab, or when assigning a value to ViewerIndex property.
Parameters:
Viewer – a viewer component corresponding to Viewers[ViewerIndex].
ViewerIndex = ViewerIndex
