TRVRuler.RichViewEdit
Specifies the editor for this ruler.
property RichViewEdit: TCustomRichViewEdit;
The ruler works differently depending on RichViewEdit.Options.
If rvoClientTextWidth is included in RichViewEdit.Options, the ruler assumes that a document width is equal to RichViewEdit.ClientWidth.
If rvoClientTextWidth is excluded from RichViewEdit.Options, when the user resizes a margin, the ruler assigns RichViewEdit.MinTextWidth and MaxTextWidth according to its PageWidth property.
