TRVFileFormatComponent, TRVHTMLComponent, TRVXMLComponent
TRVFileFormatComponent is a base class for components allowing to load and save TRichView documents in files of various formats.
Unit RVFile;
Syntax
TRVFileFormatComponent = class (TComponent);
TRVHTMLComponent = class (TRVFileFormatComponent);
TRVXMLComponent = class (TRVFileFormatComponent);
hmtoggle_arrow1Hierarchy
Description
Although RVFile unit is included in TRichView, not in RichViewActions, we describe it here, because it is used in RichViewActions.
This class is not used directly. Instead, the following inherited components are used:
TRichViewXML: allows loading, saving, and inserting XML files (an alternative to RVF);
These components are not included in RichViewActions. However, they are installed by TRichView Setup (if possible). RichViewActions can use them; but if you do not use them in your application, their code is not linked to your exe-file.
See also properties of TRVAControlPanel:
XMLComponent
