<< Click to display table of contents >> TrvActionSave.OnSaving, OnSave |
The events occur before and after saving to a file.
type
TRVSaveFileEvent = procedure (Sender: TObject;
Editor: TCustomRichViewEdit; const FileName: TRVUnicodeString;
FileFormat: TrvFileSaveFilter;
CustomFilterIndex: Integer) of object;
property OnSaving: TRVSaveFileEvent;
property OnSave: TRVSaveFileEvent;
OnSaving occurs before saving to a file. If saving shows a dialog window (for example, for choosing a text file code page), this event occurs before showing these dialogs.
OnSave occurs after successful saving. It does not occur is saving was canceled (for example, in a code page dialog), of if an error occurs when saving to a file.
Parameters:
Editor – editor for saving.
FileName – file name (full path) to save.
FileFormat – format to save.
CustomFilterIndex used only if FileFormat is ffeCustom.
If FileFormat = ffeCustom, CustomFilterIndex identifies a custom file format. Custom formats are numbered from 1 in the order they are listed in the CustomFilter property of the linked TrvActionSaveAs action.
