TrvActionParagraph.OutlineLevel
Specifies the line spacing type for applying to the selected paragraphs.
property OutlineLevel: Integer;
If UserInterface=False and rvpimOutlineLevel in ValidProperties, the action applies this property to the selected paragraphs.
If UserInterface=True, the action displays a paragraph dialog (initialized with properties of the selected paragraphs); if the user changed value of this property in the dialog, rvpimOutlineLevel is included in ValidProperties, and the action applies this property to the selected paragraphs.
This property is applied to the paragraph style's (RVStyle.ParaStyles[]) property of the same name.
