       << Click to display table of contents >> TrvActionParagraph.LineSpacing |
Specifies the line spacing value for applying to the selected paragraphs.
property LineSpacing: TRVLineSpacingValue;
If UserInterface=False and rvpimLineSpacing in ValidProperties, the action applies this property to the selected paragraphs.
If UserInterface=True, the action displays a paragraph dialog (initialized with properties of the selected paragraphs); if the user changed value of this property in the dialog, rvpimLineSpacing is included in ValidProperties, and the action applies this property to the selected paragraphs.
This property is applied to the paragraph style's (RVStyle.ParaStyles[]) property of the same name.
Meaning of this property depends on the value of LineSpacingType property. These two properties are applied together.
If LineSpacingType<>rvlsPercent, this value is measured in the same units (pixels or twips) as properties of the target editor (i.e. in RVStyle.Units).
