TrvActionParagraph.Alignment
Specifies the alignment for applying to the selected paragraphs.
property Alignment: TRVAlignment;
If UserInterface=False and rvpimAlignment in ValidProperties, the action applies this property to the selected paragraphs.
If UserInterface=True, the action displays a paragraph dialog (initialized with properties of the selected paragraphs); if the user changed value of this property in the dialog, rvpimAlignment is included in ValidProperties, and the action applies this property to the selected paragraphs.
This property is applied to the paragraph style's (RVStyle.ParaStyles[]) property of the same name.
