TrvActionInsertFile.InsertFile
Inserts the specified file.
function InsertFile(rve: TCustomRichViewEdit;
  const FileName: TRVUnicodeString;
  FileFormat: TrvFileImportFilter;
  ConverterOrCustomIndex: Integer=0;
  rvc: TRVOfficeConverter=nil;
  Silent: Boolean = False): Boolean;
Parameters:
rve – editor where to insert file.
FileName – name of the file to insert.
FileFormat – format of this file.
ConverterCustomFilterIndex used only if FileFormat is ffiCustom or ffiOfficeConverters.
If FileFormat = ffiCustom, ConverterCustomFilterIndex identifies a custom file format. Custom formats are numbered from 1 in the order they are listed in the CustomFilter property.
If FileFormat = ffiOfficeConverters, ConverterCustomFilterIndex identifies an import format, as an index in rvc.ImportConverters.
rvc is used if FileFormat = ffiOfficeConverters.
Silent – if False, the action displays an error message if the insertion was not successful.
Return value:
True if the insertion was successful.
If the insertion failed, this method displays an error message.
This method does not change values of the action's properties.
