TRVAControlPanel.UseXPThemes
Specifies whether controls on RichViewActions dialog should use Windows themes (visual styles) if available.
property UseXPThemes: Boolean;
This property affects the following controls placed on dialogs:
TRichView
TRVPrintPreview
TRVOfficeRadioButton
TRVOfficeRadioGroup
TRVColorCombo
TRVColorGrid
color picker window used in TrvActionCustomColor
Other controls use themes if it is supported by Delphi (and a manifest is included).
Default value:
True
