TRVAControlPanel.SearchScope
Defines a search scope for TrvActionFind, TrvActionFindNext, and TrvActionReplace actions.
type
  TRVASearchScope = (rvssFromCursor, rvssAskUser, rvssGlobal);
property SearchScope: TRVASearchScope;
Value
Meaning
rvssFromCursor
Searching from the caret position to the end/beginning of the document.
rvssAskUser
Searching from the caret position to the end/beginning of the document, then asking the user whether to continue from the beginning/end, then (if "yes") searching from the beginning/end.
rvssGlobal
Searching from the caret position to the end/beginning of the document, then searching from the beginning/end.
Default value:
rvssAskUser
