TRVAControlPanel.InitImportPicturesAndFiles, DoneImportPicturesAndFiles
Allows using DownloadInterface component for a loading operation that were not initialized by RichViewActions.
procedure InitImportPicturesAndFiles(Sender: TrvAction;
  Editor: TCustomRichViewEdit);
procedure DoneImportPicturesAndFiles(
Normally, when loading is initiated by an action, DownloadInterface is used automatically. The following actions initializes loading:
TrvActionOpen
TrvActionInsertFile
TrvActionPaste
TrvActionPasteSpecial
However, when loading is not initiated by an action, DownloadInterface is not used. To solve this problem, call InitImportPicturesAndFiles before loading, and DoneImportPicturesAndFiles after.
Parameters:
Sender will be used as a parameter of OnDownload event
Editor is a target editor.
Example:
This code allows downloading external pictures referred by files that are inserted in the editor as a result of drag-and-drop operation.
procedure TMyForm.MyRichViewEditBeforeOleDrop(Sender: TObject);
  MyRVAControlPanel.InitImportPicturesAndFiles(nil,
    (Sender as TCustomRichViewEdit));
procedure TForm3.RichViewEdit1AfterOleDrop(Sender: TObject);
  MyRVAControlPanel.DoneImportPicturesAndFiles(
