TCustomRuler.IndentSaturation, MarginSaturation, RulerSaturation
Saturation values of the ruler's visual elements in skin modes.
property RulerSaturation: Integer;
property IndentSaturation: Integer;
property MarginSaturation: Integer;
These properties are applied if SkinType <> stNoSkin.
RulerSaturation and RulerColor are applied to an internal ruler area.
IndentSaturation and IndentColor are applied to handles that are used to change paragraph indents.
MarginSaturation and MarginColor are applied to left and right margin areas (or top and bottom margin areas for a vertical ruler).
Default value
250
