RVA_EditorControlFunction Global Variable
This variable refers to the function allowing for the actions inherited from TrvCustomEditAction to work with additional editor types.
Unit RichViewActions;
type
  TRVAEditorControlCommand = (rvaeccIsEditorControl, rvaeccHasSelection,
    rvaeccCanPaste, rvaeccCanPasteText,
    rvaeccCanUndo, rvaeccCopy, rvaeccCut,
    rvaeccPaste, rvaeccPasteText, rvaeccUndo);
  TRVAEditorControlCommandFunction =
    function (Control: TControl;
      Command: TRVAEditorControlCommand): Boolean;
    RVA_EditorControlFunction: TRVAEditorControlCommandFunction;
By default, this variable is initialized with RVA_EditorControlFunctionDef function.
Command
The function must...
... return True if Control is a supported editor control.
rvaeccHasSelection
... return True if the selection in Control is not empty
rvaeccCanPaste
... return True if Control can paste data from the Clipboard.
rvaeccCanPasteText
... return True if Control can paste text from the Clipboard.
rvaeccCanUndo
... return True if Control can undo the last editing operation
rvaeccCopy
... copy the selection from Control to the Clipboard
rvaeccCut
... cut the selection from Control to the Clipboard
rvaeccPaste
... paste data from the Clipboard into Control
rvaeccPasteText
... paste text from the Clipboard into Control
rvaeccUndo
... undo the last editing operation in Control
