Third-Party Tools | Fugue Icons Toolbar Images
Fugue Icons
(deprecated, this datamodule the not maintained anymore)
If you want to use modern looking images, consider Fugue Icons toolbar images.
Fugue Icons – Copyright © 2009 Yusuke Kamiyamane.
The icons can be used free for any personal or commercial projects under a Creative Commons Attribution 3.0 license.
If you can't or don't want to place link to the icons author website , please visit p.yusukekamiyamane.com and purchase a royalty-free license.
Download a datamodule with these icons from http://www.trichview.com/resources/actions/dmactionsfugue.zip
For Delphi 2009+ only (because of semitransparent images)
The datamodule contains 2 identical sets of icons: with and without shadows.
Installing
It's not necessary to install files to use this datamodule.
However, If you want to use the datamodule at design time instead of dmActions.pas:
1.Open RichViewActions.inc and remove the dot from one of the following line:
{.$DEFINE USEFUGUEICONS}  // to use dmActionsFugue (1 byte transparency, D2009+)
2.Remove dmActions.pas from the RichViewActions package
3.Install (or recompile) the package.
Additional information
Additional information is available on the support forum.
