Hello again,
At he first camerasearch event my camera search popup is displayed no problem.
But when after a status is <> 0 in searchcomplete a retry of the camerasearch event
is called, at the retry the camerasearch popup is no longer visible.
Is this possible to do ?
Would give a better idea when each attempt at a reconnect to the camera is busy.
I tried resetting ShowCameraSearch to true after the fail but no luck.
In average i have to retry a connect 4 to 5 times before connecting.
Once again big thanks for these components.
I managed to connect to a Foscam Cam also.
Redisplaying the animated camera search popup ?
Re: Redisplaying the animated camera search popup ?
Do you use the newest version of RVMedia?
6.1.
The strange thing is, once connected the cams stay connected.
Can you help us to reproduce this problem?
Can you open this camera for us temporarily?
