Why the installer skipps the installation of the unidac data provider??
how to fix it,.
trichview+srv+rws
Installing optional DevArt UniDAC data provider... Skipped.
Re: Installing optional DevArt UniDAC data provider... Skipped.
Run RAD Studio, open UniDAC support package. It is in ReportWorkshop\DataProvides\Source folder. Package names are RW_Uni_*.dproj. For example, for Delphi 10.2, the package name is RW_Uni_D10_2.dproj. Open it and compile. Post error messages in this topic.
I downloaded a new version of UniDAC (trial) for Delphi 6 and Delphi 10. Report Workshop successfully installed UniDAC support package.
So please check if UniDAC is installed.
I guess it is the unidac version. i was able to install it but it showed some function, methods errors (methods not supported)
I forgot to save the errors, sorry. for now I will be testing it.
thank you,
thank you,
