SRVE Changes page orientation after TsrvActionPrint executin
vit
Post by vit »
Hi!
1. I load RVF in SRVE (document has landscape orientation)
2. Click Print button (use TsrvActionPrint action)
3. In Print dialog click OK
4. Now document orientation is Portrait.
Not able to reproduce it in ActionTest but It happens in between 2. and 3. (I found it out with debugger) at the line
FPageProperty.FOrientation := Orientation;
here is the stacktrace
SclRView.TSRichViewEdit.SetRVMargins(False)
SclRView.TSRichViewEdit.Reformat
SclRView.TSRVPageProperty.SetPageFormat(srvfmA4)
SRVActions.TsrvCustomActionThatNeedsDocProps.SetMultipageLayout($1300AB20)
SRVActions.TsrvActionPrint.Print($1300AB20)
here are settings that are set in my SRVE
  RVOptions := [rvoAllowSelection, rvoScrollToEnd, rvoAutoCopyText,
    rvoAutoCopyRVF, rvoAutoCopyImage, rvoAutoCopyRTF, rvoFormatInvalidate,
    rvoDblClickSelectsWord, rvoRClickDeselects];
  RTFOptions := [rvrtfDuplicateUnicode, rvrtfSaveEMFAsWMF, rvrtfSaveJpegAsJpeg,
    rvrtfSaveDocParameters];
  RTFReadProperties.UnicodeMode := rvruMixed;
  RTFReadProperties.TextStyleMode := rvrsAddIfNeeded;
  RTFReadProperties.ParaStyleMode := rvrsAddIfNeeded;
  RTFReadProperties.ReadDocParameters := True;
  RVFOptions := [rvfoSavePicturesBody, rvfoSaveControlsBody,
    rvfoIgnoreUnknownPicFmt, rvfoIgnoreUnknownCtrls,
    rvfoConvUnknownStylesToZero, rvfoConvLargeImageIdxToZero, rvfoSaveBinary,
    rvfoSaveBack, rvfoLoadBack, rvfoSaveTextStyles, rvfoSaveParaStyles,
    rvfoSaveLayout, rvfoLoadLayout, rvfoSaveDocProperties,
    rvfoLoadDocProperties];
SRV_VERSION = 'v7.2.1';
RVE: v16.3.1 (2015-Nov-6)
RVA: v6.2.1
Any thoughts what reason may be?
Thanks!
Do you have TrvActionSave?
It is necessary for ScaleRichView printing actions.
Even if you do not need TrvActionSave (for example, you store documents in a database instead of files), add it (and, if you do not need it to be executed, clear its Shortcut property)
vit
Post by vit »
I've just tried it didn't help (both TrvActionSave and TsrvActionPrint are on a TDataModule)
Is it possible to reproduce the problem in a simple project?
As I understand, the problem happens when TSRichViewEdit in the method SetRVMargins synchronizes PageProperty and RichViewEdit.DocParameters (assigns Orientation from RichViewEdit.DocParameters to PageProperty).
I do not understand why these orientations are different. When you load a file, the component first loads page properties in RichViewEdit.DocParameters, and then assigns them to PageProperty, so properties must be equal.
vit
Post by vit »
Yes, it seems that orientations differ for some reason. I'm still unable to reproduce it, but I'm going to bring a file I load soon. Maybe it'll help
vit
Post by vit »
Not sure if it may help but I brought two files.
First file is RVF I save just after opening a content in my SRVE http://webfiles.ru/files/45489279. It's disappointing that when I open it in ActionTest the page orientation is Portrait. Despite of the fact that it was saved with the Landscape and it had the Landscape orientation just after openning in my SRVE. Could you please find out which orientation is written inside the file?
And second file is RVF as well, I saved it just after printing http://webfiles.ru/files/45489280 when the orientation has been changed
This information can be seen in any text editor.
Page information is the same in table.rvf and table1.rvf:
Units=1
PageHeight=29.7
PageWidth=21
LeftMargin=1.5
RightMargin=1.5
HeaderY=1
FooterY=1
For portrait orientation, the line
Orientation=1
must be there.
Daisyvop
Post by Daisyvop »
Hi
Is there way to set in SRVE different margins for different pages after page break?
In Page Setup form is possible to set margins for entire document only.
Re: SRVE Changes page orientation after TsrvActionPrint executin
Sorry, different margins for different pages are not implemented yet.
