[Demos] Mail Merge
Ceprotec
Re:
Post by Ceprotec »
Sergey Tkachenko wrote: Tue May 05, 2009 1:37 pm MainMerge-Text4
mailmerge-text4.zip
The same as MailMerge-text3, but supports several types of field values.
Field codes: text in {}, for example {NAME}.
Field values: multiline text / picture / table / arbitrary document (RVF)
[+] History of updates
2015-Mar-26: RVF field type is added
2018-Apr-30: compatibility with TRichView 17.3. Unicode text in all versions of Delphi. Tab characters are allowed in text field values.
[+] Old versions
https://www.trichview.com/support/files ... -text4.zip - for TRichView 17.2 and older
How to insert the RVF in the same line as the field?
Re: Re:
Ceprotec wrote: Wed Nov 15, 2023 12:52 am How to insert the RVF in the same line as the field
See MailMerge-Text4 demo: https://www.trichview.com/forums/viewto ... 707#p12707
Ceprotec
Re: Re:
Post by Ceprotec »
Sergey Tkachenko wrote: Wed Nov 15, 2023 7:17 am
This is the MailMerge-Text4 demo.
Re: [Demos] Mail Merge
Oh, sorry.
But I do not understand the question.
In this demo, the field content (RVF or text) is inserted in the line that contains field code.
You edited the template so that it contains a single line, so RVF field is inserted in this line.
(this demo repeats the result for each line in Persons.txt)
Ceprotec
Post by Ceprotec »
I would like to insert the RVF at the end of the template line and not on a new line...
I can adapt this function to only remove the last blank line.
Sergey Tkachenko wrote: Wed Nov 02, 2005 9:19 pm Modification of DeleteBlankLines - removing blank lines only from the end of the document:
procedure DeleteTrailingBlankLines(RVData: TCustomRVData);
var i: Integer;
  for i := RVData.ItemCount-1 downto 1 do
    if RVData.IsParaStart(i) and (RVData.GetItemStyle(i)>=0) and
      (RVData.GetItemText(i)='') then
      RVData.DeleteItems(i,1)
      break;
Call:
DeleteBlankLines(RichViewEdit1.RVData);
RichViewEdit1.ClearUndo;
RichViewEdit1.Format;
I don't think it's very elegant, is there any other way to do this?
So, you want to add the first paragraph of each record to the last paragraph of the previous record?
Change TForm1.Button1Click. The key method is AppendRVFFromStream(..., -1).
var Stream: TStream;
    ItemCount: Integer;
  Index := 0; // index of the current person
  ItemCount := 0;
  rvOutput.Clear;
  while Index<Persons.Count do
    // copying rve to the end of rvOutput
    rve.SaveRVFToStream(Stream, False);
    Stream.Position := 0;
    if Index = 0 then
      rvOutput.InsertRVFFromStream(Stream, ItemCount)
      rvOutput.AppendRVFFromStream(Stream, -1);
    Stream.Free;
    // processing the last added copy of template
    if rvOutput.ItemCount>ItemCount then
      // replacing field codes
      FillFields(rvOutput.RVData, ItemCount);
    ItemCount := rvOutput.ItemCount;
    inc(Index);
  rvOutput.Format;
