[Example] Typing opening and closing quotes
The example automatically changes typed " and ' characters to the appropriate opening or closing quote.
The result depends on the keyboard language:
“ ” (example: English)
„ “ (example: German)
„ ” (example: Polish)
« » (example: Russian)
» « (Danish)
” ” (Finnish, Swedish)
I based this work on the following tables:
http://en.wikipedia.org/wiki/Internatio ... tion_marks
http://technet.microsoft.com/en-us/libr ... 25682.aspx
If this procedure chooses an incorrect (or not traditional) quotes for your language, please report to richviewgmailcom or to this topic.
How it works.
In OnKeyPress event, we check for ' and " characters. If one of these characters is typed, we find an appropriate replacement using GetQuote().
Of course, we can assign this replacement character to Key parameter of OnKeyPress, but this is not a good solution, because undo will simple delete this character. Instead, we assign this character to a global variable ReplaceChar, and perform a replacement in OnChange event. In this way, the first undo will revert a quote replacement, the second undo will delete a typed character.
The code below is for TRichView version 17.2 and older. For newer versions of TRichView, see http://www.trichview.com/forums/viewtop ... 706#p34706
uses RVUni;
{$IFnDEF UNICODE}
const LDQuo = #147;
const RDQuo = #148;
const LAQuo = #171;
const RAQuo = #187;
const LSQuo = #145;
const RSQuo = #146;
const BDQuo = #132;
{$ELSE}
const LDQuo = #$201C;
const RDQuo = #$201D;
const LAQuo = #$00AB;
const RAQuo = #$00BB;
const LSQuo = #$2018;
const RSQuo = #$2019;
const BDQuo = #$201E;
{$ENDIF}
function GetQuote(rve: TCustomRichViewEdit; Ch: Char): Char;
var ItemNo1, ItemNo2, Offs1, Offs2: Integer;
    DelimBefore, DelimAfter: Boolean;
    function IsDelim(ItemNo, Index: Integer): Boolean;
      s : String;
      {$IFnDEF UNICODE}
      CodePage: Cardinal;
      {$ENDIF}
      s := rve.GetItemText(ItemNo);
      if (Index>Length(s)) or (Index<0) then begin
        Result := True;
      {$IFnDEF UNICODE}
      CodePage := rve.RVData.GetItemCodePage(ItemNo);
      {$ENDIF}
      Result :=
        {$IFDEF UNICODE}
        rve.RVData.IsDelimiterW(s[Index])
        {$ELSE}
        rve.RVData.IsDelimiterA(s[Index], CodePage)
      {$ENDIF}
    function DoGetQuote(Opening: Boolean): Char;
    var Lang: Cardinal;
      Lang := RVU_GetKeyboardLanguage;
      case Ch of
        case Lang of
        // Albanian, Bulgarian, Czech, Estonian, Georgian,
        // German,
        // Icelandic, Lithuanian, Macedonian,
        // Slovak, Slovene, Sorbian
        $041c, $0402, $0405, $0425, $0437,
        $0c07, $0407, $1407, $1007,
        $040f, $0427, $042f,
        $041b, $0424, $082e:
          if Opening then
            Result := BDQuo
            Result := LDQuo;
        // Croatian, Hungarian, Polish, Romanian,
        // Serbian,
        $041a, $101a, $040e, $0415, $0418,
        $1c1a, $181a, $301a, $2c1a, $281a, $241a, $0c1a, $081a:
          if Opening then
            Result := BDQuo
            Result := RDQuo;
        // Armenian, Azerbaijani, Basque, Belarusian, Catalan,
        // French,
        // German-Swiss,
        // Greek, Italian, Latvian, Norwegian
        // Persian, Portuguese, Russian,
        // Spanish,
        // Ukrainian
        $042b, $082c, $042c, $042d, $0423, $0403,
        $080c, $0c0c, $040c, $140c, $180c, $100c,
        $0807,
        $0408, $0410, $0810, $0426, $0414, $0814,
        $0429, $0416, $0816, $0419,
        $2c0a, $200a, $400a, $340a, $240a, $140a, $1c0a, $300a, $440a, $100a,
        $480a, $080a, $4c0a, $180a, $3c0a, $280a, $500a, $0c0a, $040a, $540a, $380a,
        $0422:
          if Opening then
            Result := LAQuo
            Result := RAQuo;
        // Danish
        $0406:
          if Opening then
            Result := RAQuo
            Result := LAQuo;
        // Finnish, Swedish
        $040b, $081d, $041d:
          Result := RDQuo;
          if Opening then
            Result := LDQuo
            Result := RDQuo;
        case Lang of
        // Finnish, Swedish
          Result := RSQuo;
          if Opening then
            Result := LSQuo
            Result := RSQuo
        end
        Result := Ch;
  // Returing the original character by default
  Result := Ch;
  rve := rve.TopLevelEditor;
  if rve.SelectionExists then
  // Finding the position before (ItemNo1, Offs1) and after (ItemNo2, Offs2) the insertion point
  ItemNo1 := rve.CurItemNo;
  Offs1 := rve.OffsetInCurItem;
  if Offs1<=rve.GetOffsBeforeItem(ItemNo1) then begin
    ItemNo2 := ItemNo1;
    Offs2 := Offs1;
    dec(ItemNo1);
    if ItemNo1>=0 then
      if not rve.IsFromNewLine(ItemNo1) then
        Offs1 := rve.GetOffsAfterItem(ItemNo1)
      else begin
        ItemNo1 := -1;
        Offs1 := -1;
      end
      Offs1 := -1;
    end
  else if Offs1>=rve.GetOffsAfterItem(ItemNo1) then begin
    ItemNo2 := ItemNo1+1;
    if ItemNo2<rve.ItemCount then
      if not rve.IsFromNewLine(ItemNo2) then
        Offs2 := rve.GetOffsBeforeItem(ItemNo2)
      else begin
        ItemNo2 := rve.ItemCount;
        Offs2 := -1;
      end
      Offs2 := -1;
    end
  else begin
    ItemNo2 := ItemNo1;
    Offs2 := Offs1;
  // Is a delimiter (or nothing, or non-text) before the insertion point?
  if (ItemNo1<0) or (rve.GetItemStyle(ItemNo1)<0) or
    (rve.Style.TextStyles[rve.GetItemStyle(ItemNo1)].Charset=SYMBOL_CHARSET) then
    DelimBefore := True
    DelimBefore := IsDelim(ItemNo1, Offs1-1);
  // Is a delimiter (or nothing, or non-text) after the insertion point?
  if (ItemNo2>=rve.ItemCount) or (rve.GetItemStyle(ItemNo2)<0) or
    (rve.Style.TextStyles[rve.GetItemStyle(ItemNo2)].Charset=SYMBOL_CHARSET) then
    DelimAfter := True
    DelimAfter := IsDelim(ItemNo2, Offs2);
  // Choosing a quote
  if DelimBefore and not DelimAfter then
    Result := DoGetQuote(True)
  else if not DelimBefore and DelimAfter then
    Result := DoGetQuote(False);
// this variable can be moved to a form
const ReplaceChar: Char = #0;
procedure TForm3.RichViewEdit1KeyPress(Sender: TObject; var Key: Char);
  ReplaceChar := #0;
  if (Key='"') or (Key='''') then begin
    ReplaceChar := GetQuote(RichViewEdit1, Key);
    if ReplaceChar=Key then
      ReplaceChar := #0;
procedure TForm3.RichViewEdit1Change(Sender: TObject);
var rve: TCustomRichViewEdit;
    ItemNo, Offs: Integer;
    Ch: Char;
  if ReplaceChar<>#0 then begin
    Ch := ReplaceChar;
    ReplaceChar := #0;
    rve := RichViewEdit1.TopLevelEditor;
    ItemNo := rve.CurItemNo;
    Offs := rve.OffsetInCurItem;
    rve.SetSelectionBounds(ItemNo, Offs-1, ItemNo, Offs);
    rve.InsertText(Ch);
DavidRM
Post by DavidRM »
I was unable to get this code to work as expected. I essentially just copied-and-pasted it in. The results are very inconsistent.
My own implementation boils down to this logic:
when user types a " or '
  if this is the beginning of a new paragraph, or if the previous character is whitespace
    replace with an open/left quote
    replace with a close/right quote
From my experimenting with MS Word 2003, they use pretty much the same simple logic.
-David
In this case, you can change the code fragment
to
Result := DoGetQuote(DelimBefore)
Re: [Example] Typing opening and closing quotes
This code is for TRichView 17.3 and newer (till version 18, see below).
uses RVTypes, CRVData, RVUni;
function GetQuote(rve: TCustomRichViewEdit; Ch: TRVUnicodeChar): TRVUnicodeChar;
  ItemNo1, Offs1: Integer;
  DelimBefore: Boolean;
  Lang: Cardinal;
  OpeningQuote: TRVUnicodeChar;
    // Returns True if the Index-th character in the ItemNo-th item is a delimiter,
    // but not an opening quote
      s : TRVUnicodeString;
        Result := True;
      Result := (s[Index] <> OpeningQuote) and rve.RVData.IsDelimiterW(s[Index])
    function DoGetQuote(Opening: Boolean): TRVUnicodeChar;
      case Ch of
        case Lang of
        // German,
          if Opening then
            Result := UNI_RIGHT_DOUBLE_LOW_QUOTE
            Result := UNI_LEFT_DOUBLE_QUOTE;
        // Serbian,
          if Opening then
            Result := UNI_RIGHT_DOUBLE_QUOTE;
        // French,
        // German-Swiss,
        // Spanish,
        // Ukrainian
        $0807,
        $0422:
          if Opening then
            Result := UNI_LEFT_DOUBLE_ANGLE_QUOTE
            Result := UNI_RIGHT_DOUBLE_ANGLE_QUOTE;
        // Danish
        $0406:
          if Opening then
            Result := UNI_LEFT_DOUBLE_ANGLE_QUOTE;
        // Finnish, Swedish
          if Opening then
        case Lang of
        // Finnish, Swedish
          Result := UNI_RIGHT_SINGLE_QUOTE;
          if Opening then
            Result := UNI_LEFT_SINGLE_QUOTE
        end
        Result := Ch;
  Result := Ch;
    dec(ItemNo1);
    if ItemNo1>=0 then
        ItemNo1 := -1;
        Offs1 := -1;
      end
      Offs1 := -1;
  // Getting the keyboard language and opening quote
  OpeningQuote := DoGetQuote(True);
    rve.Style.TextStyles[rve.GetItemStyle(ItemNo1)].IsSymbolCharset then
    DelimBefore := True
  // Choosing a quote
  Result := DoGetQuote(DelimBefore);
const ReplaceChar: TRVUnicodeChar = #0;
  ReplaceChar := #0;
    ReplaceChar := GetQuote(RichViewEdit1, TRVUnicodeChar(Key));
    if ReplaceChar=TRVUnicodeChar(Key) then
      ReplaceChar := #0;
    Ch: TRVUnicodeChar;
    Ch := ReplaceChar;
    ReplaceChar := #0;
    rve.InsertTextW(Ch);
In this update, all text is processed as Unicode.
Also, this update fixes the problem with a separate quote (noticed by DavidRM) - it must be an opening quote.
Also, this update fixes the problem with a quote after an opening quote - it must be a closing quote.
rhett.price
Post by rhett.price »
In version 18 - this code breaks on reference to:
Could we get updated code that works in v18?
Thanks!
Rhett Price
IndySoft
rhett.price
Ah, I see. Just change function to RVGetKeyboardLanguage and add RVKeyboardFuncs to the uses and it looks like we're good now.
Thanks,
Rhett
Thank you!
Here is the code changed for compatibility with TRichView 18 and newer.
uses RVTypes, CRVData, RVUni, RVKeyboardFuncs;
  Lang: Cardinal;
        Result := True;
      case Ch of
        case Lang of
        // German,
          if Opening then
        // Serbian,
          if Opening then
        // French,
        // German-Swiss,
        // Spanish,
        // Ukrainian
        $0807,
        $0422:
          if Opening then
        // Danish
        $0406:
          if Opening then
        // Finnish, Swedish
          if Opening then
        case Lang of
        // Finnish, Swedish
          if Opening then
        end
        Result := Ch;
  Result := Ch;
    dec(ItemNo1);
    if ItemNo1>=0 then
        ItemNo1 := -1;
        Offs1 := -1;
      end
      Offs1 := -1;
  Lang := RVGetKeyboardLanguage;
    DelimBefore := True
  // Choosing a quote
  ReplaceChar := #0;
      ReplaceChar := #0;
    Ch: TRVUnicodeChar;
    Ch := ReplaceChar;
    ReplaceChar := #0;
