New demo: master-detail reports
Master-details demo:
http://www.trichview.com/support/files/ ... detail.zip
This demo supports multiline text and picture fields. Fields are defined as text inside {}.
A template in this demo may contain tables linked to datasets. Such tables have a repeated group of rows; they are repeated as many times as many records in the linked dataset. If such table is inserted in a repeated row of another table, a master-detail relationship is established (a nested table becomes a detail table). Tables can be nested on any depth. The demo shows 3 levels of tables.
The demo uses Paradox tables, so BDE is required.
Detailed comments are at the beginning of the main form's unit.
The demo can be easily customized to use another set of data (functions that need not to be modified are marked in the code)
