Play video from TMemoryStream
Elivaldo
Post by Elivaldo »
Is it possible to play a video from a TMemoryStream?
Thanks!
Re: Play video from TMemoryStream
Sorry, it's not supported, you need to save it to a temporary file.
What's the format of this video?
Elivaldo
Post by Elivaldo »
Thank you Sergey for your answer.
This TMemoryStream is a MP4 video. After saving it to a file, how can I play it?
Assign:
RVCamera.SourceFileName = path to this file
RVCamera.DeviceType = rvdtFile.
Call RVCamera.PlayVideoStream.
In Windows, RVCamera can play local files either using FFmpeg or using DirectX.
The main difference is in processing sound from videos.
FFmpeg is used, if FFmpeg libraries are available, and RVCamera.FFMpegProperty.UseFFMPEG=True.
In this case, sound from video can be read by TRVCamSound component linked to this TRVCamera (and then played or recorded using TRVAudioPlayer component),
Otherwise, DirectX is used. In this case, sound is just played using DirectX.
Elivaldo
Post by Elivaldo »
Thank you so much, Sergey! :)
